Select the property, click Setup, and then click Workstations.
Double-click the workstation to be used with the MSR.
Click the Options tab, and then
click the Display/Security subtab.
Select the appropriate MSR options.
Table 44-5 MSR Workstation Options
Option
Description
12 - Mag Card Entry Required for Employee ID
Select this option to allow all employee ID entries at the
workstation to be made by swiping a magnetic employee ID card. The
workstation does not accept an employee ID number entered through
the keyboard or touchscreen.
50 - Mag Card or Fingerprint Scan Required for Employee
ID
workstation to be made using a fingerprint scan or by swiping a magnetic
card. That is, employees must swipe a card or scan a fingerprint.
51 - Mag Card and Fingerprint Scan Required for Employee
ID
workstation to be made using a fingerprint scan and by swiping a magnetic
card. That is, employees must both swipe a card and scan a fingerprint.
If you are using an encrypted MSR (for example, the MSR
sleeve for Oracle MICROS Tablet E-Series 8-inch and 11-inch devices
with Transaction Vault Second Generation (TV2G)), take note of the
following:
Simphony 19.1 and later no longer support the option 55 - Enable Encrypted Magnetic Stripe Reader Support.
Click the Devices tab.
Click Add, and then select a magnetic
stripe reader from the Select Peripheral Device Type drop-down list.
Select the COM Port Settings (if necessary), and then click OK.
