Configuring the Change Default Printer Destination Button
You need to create a button which allows workstation operators to set and reset the default printer selection.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the Front of House page on which to place the Change Default Printer Destination button,
- On the Edit tab, select the page area in which to define the button.
- Click Button.
- On the General subtab, enter the button name in the Legend field.
- From the Type drop-down list, select Function.
- Click the black arrow beneath the Type drop-down list, select Change Default Printer Destination, and then click OK.
- Position and size the button on the page. Use the Style arrow to change the color.
- Click Save.
Parent topic: Printers
