Configuring the Barcode Scanner on the Oracle MICROS Tablet 720
The Oracle MICROS Tablet 720 comes with a built-in OPOS Barcode
Scanner.
- In EMC, select Property, Setup, Hardware/Interfaces, Workstations, and then Devices.
- In the Peripheral Device Configuration section, click Add.
- For Select Peripheral Device Type, select OPOS Barcode Reader.
- For Configuration, enter Honeywell.
- Click OK, and then Save.
The Oracle MICROS Tablet 720 Setup Guide contains
more information on setting up and using the Tablet 720.
Parent topic: POS Workstations
