Select the property, click Setup, and then click RVC Configuration.
Insert a record.
From the Add Revenue Center dialog, enter the RVC Number and the RVC Name.
(Optional) To copy information from an existing revenue
center, select Copy from source Revenue Center from the Source Revenue Center section. The hierarchy panel and Modules To Copy fields become active.
From the hierarchy panel, select the revenue center
to use as the source revenue center.
From the Modules to Copy section, select the modules
you want to copy from the source revenue center. To automatically
select all modules, click the Select All Modules link.
(Optional) Select Distribute inherited records to distribute all records (defined and inherited) from the source
revenue center to the new revenue center. Deselect this option to
distribute only records defined at the source revenue center to the
new revenue center.
(Optional) Select If destination record is
inherited, create override to create an override record
in the new revenue center when an inherited definition exists.
(Optional) Select Distribute Data Extensions
if they exist to distribute data extension values if they
exist.
Click OK to copy the records from
the source template revenue center to the new revenue center.
(Optional) Toggle to Form view. The content in the General
section is meant for users of Simphony Transaction Services (STS)
Gen 2. If you want customers to view your Revenue Center name and
location information via STS Gen 2, complete this section.
See Transaction Services for more information about Transaction Services Gen 1 and STS Gen
2.
Toggle to Table view and select the following options as
applicable for the new revenue center:
LDS Active: Select this option if the
revenue center uses a Liquor Dispensing System (LDS), which is a third-party
system used for pouring and tracking liquor and beverages, as well
as mixed drinks.
KDS Controller: Select the KDS Controller
to control the kitchen display system (KDS) order devices in the revenue
center.
Click Save.
After adding a new revenue center, restart the workstation
to ensure changes are saved.
