Configuring the Android Device as a Workstation
Perform the following steps before installing Simphony software.
- Configure the Android device to be a member of the POS network using a static Internet Protocol (IP) address.
- Install antivirus software on the device.
- Turn off Trusted Sources on the device. See the manufacturer instructions for details.
- If you are using a Bluetooth printer, pair it with the device. See the manufacturer instructions for details.
Related Topics
- Configuring an Android Workstation
- Viewing and Editing Simphony Android Files
- Installing the Android Service Host
- Upgrading and Downgrading the Android Service Host
- Workaround for Android Lollipop 5.0.2 and 5.1
- Workstation Tasks
- POS Clients Running Android Mobile Operating System
- Android Functionality Support
- Android Network Requirements
- Android Payments
Parent topic: POS Clients Running Android Mobile Operating System
