Configuring Target Turn Times
Target Turn Times define the target time from seating to request completion for a seated party. Target Turn Times also affect the following seating-related operations:
  • Prevent reservation overbooking
  • Estimate wait times for walk-in table requests
  • Anticipate the tables that will be available in order to distribute the table seating appropriately
  1. Select the revenue center, click Setup, and then click Reservation Periods.
  2. Open the reservation period record.
  3. Click the General tab, and then click the Target Turn Times subtab.
  4. Click the Add link.
  5. Enter information in the Target Turn Times fields:
    Table 51-25 Target Turn Times
    Field Description
    Begin Time
    Enter the time when the defined Cover Count and Target Turn Time begins.
    End Time
    Enter the time when the defined Cover Count and Target Turn Time ends.
    Cover Count
    Enter the number of covers seated at the table.
    The Cover Count value cascades to lower values if you do not set a lower value. For example, if you set a cover count of 4, the cover includes requests for a party of 1 through 4. However, setting a lower capacity of 2 applies to parties of 1 or 2, and the capacity of 4 applies to parties of 3 or 4.
    Minutes
    Enter the anticipated turn time (in minutes) for a table seating of the defined Cover Count during the specified timeframe. If you do not create a Target Turn Time, the application uses the default value of 60.
    For example, if you enter 45, table seatings that encompass the defined cover count during the timeframe assume the seating request is 45 minutes in duration.
  6. Click Save.
