Uploading Data to the Target Environment
  1. Log in to the new target environment.
  2. Click Clone Config on the toolbar.
  3. Drag and drop the data ZIP file to the Import Configuration window or click the link to upload the file. Do not unzip the data ZIP file first.
  4. Click Import Configuration File.
  5. After the upload is complete, verify the configuration settings in the new environment.
    If the upload fails, review the error messages returned by the clone tool, and then try the upload again.
    If configuration data exists in the target environment, the clone tool detects the data during the upload. To overwrite the existing data with the data you are uploading, click Erase Data & Proceed.
