Changing the Appearance of Workstations
  1. Select the Enterprise, property, or zone, click Configuration, and then click Theme Assignment.
  2. Change the following settings:
    • Default Theme: Select the default theme for the workstations.
    • Default Palette: If you selected Edge as the Default Theme, select the color palette for the theme.
  3. Click Save.
