Configuring Security Questions
After you successfully log on to the EMC or to the Simphony Web Portal, if your security questions or email address have not yet been configured, you are prompted to configure them. The message prompt window contains a link to the User Profile page of the Import/Export application, which opens in a browser.
The following figure shows samples of the security questions that are available for you to provide responses as you configure the User Profile section.
Figure 2-14 Security Questions
Parent topic: Post-Installation Configuration
