Team Check and Guest Check Combination
Privileged operators can add regular guest checks to team checks and vice versa.
  • When a regular check is added to a team check, the resulting check retains the team members.
  • When a team check is added to a regular check, the resulting check is a regular guest check with no team assignment.
  • When two team checks are combined, the team of the check added to is retained.
See Combining Checks in the Same Revenue Center into One Order and Combining Checks Across Revenue Centers into One Order for instructions on merging checks.
