Tracking Engagement Usage
You can track the number of organizations, workstations, and employees using Engagement.
Click the Menu bar, and then click Usage. You can view the following:
Adoption rate
Widget use
Frequency with which the Hub page is opened
You can filter the usage information by:
Organization
Timeframe
Custom Date Range (Start and End dates)
Parent topic: Engagement Cloud Service
