Employee Lines
After you assign employees to tables and sections, an optional Employee Lines feature shows the table assignments. A line appears from the employee name label to the table.
To show Employee Lines, long-press on the Host Command area and select Show Employee Lines.
To hide the Employee Lines, long-press on the Host Command area and select Hide Employee Lines.
