Adding the Guest Count to a Check
The guest count (sometimes referred to as cover count) is the number of guests assigned to a guest check. You can use the following methods to assign the guest count, depending on the configuration:
  • Begin a check
  • Use the Number of Guests function key during a transaction
  • Pick up a check and perform a service charge
  • Add a menu item (for example, a particular beverage) to the check
  1. To add the guest count when beginning a check:
    1. Sign on to the workstation.
    2. Click a Begin Check function key.
    3. Enter the number of guests at the workstation prompt.
  2. To change the count on an open check during a transaction:
    1. Click the Number of Guests function key.
    2. Enter the number of guests at the workstation prompt.
