Adding Suites Owner Information to a Check
  1. Press the Add Check to Suite function key, enter the suite number, and then press OK.
  2. Enter the suite guest name, and then press OK.
  3. Enter the number of the check to add guest information, and then press OK.
  4. Select the suite guest name that you entered in Step 2 from the suites owner list, and then press OK.
  5. Make the necessary changes, and then end the current service round of the Suites check.
