Applying a Discount Manually
You can apply a manual discount to an entire check or to a single item on the check.
  1. Begin a check and add menu items.
  2. Select the button configured for the appropriate discount.
  3. If the discount is an open discount, enter the discount amount or percentage, and then click OK.
  4. If the workstation prompts, enter the discount reference details, and then click OK.
  5. To apply a discount to a menu item on the check:
    1. Select the menu item, and then select the button configured for the appropriate discount.
    2. Repeat Steps 3 and 4.
