Using PATT with One Credit Card
Complete the following steps when using PATT for a guest paying the entire check:
  1. Add menu items.
  2. Press the Pay at the Table (PATT) function.
  3. (Optional) Select a different language from the drop-down list to translate the entry fields.
  4. Tap Next on the initial PATT page.
  5. If the guest wants to change the tip percentage or amount, on the Add a Tip page, tap the Text field, enter a different tip value, and then tap Next.
  6. To send an electronic receipt with signature to the guest, enter a valid email address, and then tap Next. If the guest does not want to receive an electronic receipt, leave this field blank.
  7. Swipe the guest’s credit card.
  8. Enter the guest’s signature on the device, and then tap Next.
