Clocking In and Out
Employees assigned to one or more one job codes must clock in. When a workstation is offline but can communicate with other workstations and services, employees can clock in. When a workstation is offline (no network communication) and unable to communicate with other workstations and services, employees cannot clock in.
- Click the Clock In function key.
- If you have multiple job codes, select the job code, and then click OK.
- If you have privileges, change the revenue center, and then click OK.
- Close all guest checks before clocking out at the end of a shift unless you have the privilege to clock out with open checks.
- Click the Clock Out function key.
Parent topic: Start of Shift
