Issuing a Batch of Gift Cards
You can perform this operation only with Oracle Hospitality Gift and Loyalty. You cannot perform this operation with a third-party stored value application.
You can use the Issue Batch function to issue multiple cards for the same amount (rather than issuing each one individually).
- Begin a check.
- Navigate to the gift and loyalty screen, and then select the function key to issue gift cards in bulk.
- Select the stored value program, and then click OK.
- Enter the card amount.
- Enter the number of cards to issue, and then click Yes on the confirmation message.
- Swipe each card or enter each card number, and then click OK on the confirmation message.
- Pay the check to a tender, such as cash or credit card.
Parent topic: Loyalty and Gift Cards
