Seating a Guest Using Quick Seat
You can rapidly seat a guest using the Quick Seat feature without adding them to the Wait List.
  1. Double-tap the table. (Do not highlight or select anything on the Wait List.)
  2. Change the Cover Count on the Quick Seat dialog by entering a new number, or using the + and buttons, and then clicking OK.
    • If you attempt to quick seat a guest with covers below or above the minimum or maximum table capacity, the application prompts you to confirm.
    • If you attempt to quick seat a guest at a table that does not meet the system requirements (for example, the table is unavailable or unassigned), the application prompts you for authorization if you do not have the appropriate privilege.
  3. Click Yes at the prompt to begin a new guest check. Seat the guest at the table.
Related Topics
