Components with Condiments
Components inherit the required and allowed condiments of the parent menu item. If you override a component assigned to a parent menu item from the property, revenue center, or zone, you must reassign condiments to that component.
When condiments have prep times, Simphony adds or deducts the condiment’s prep time from the prep time of its component. However, when the parent menu item also fires to a Prep Station, Simphony adds or deducts from the parent’s prep time.
Set up components with condiments in the following order:
Create components
Assign components to the parent menu item
Assign condiments to the components
Related Topics
Parent topic: Menu Item Components
