Allowing Employees to Install and Authenticate POS Clients and Service Hosts
Beginning with Simphony version 2.9.1 and later, you must allow employees to download software, install, and authenticate clients and service hosts using CAL version 139. When this privilege is granted, the User Security Credentials configured in the Property Parameters module become inactive, allowing employees to use their EMC login credentials when setting up POS clients.
- Select the Enterprise, click Configuration, and then click Roles.
- Double-click an employee role.
- Click the Operations tab, click the Miscellaneous subtab , and then select 10065 - Download Software, Install and Authenticate Clients and Service Hosts Using CAL.
- Click Save.
Parent topic: Client Application Loader (CAL) Setup for KDS
