Select the revenue center, click Setup, and then click KDS Distribution Groups.
Insert a record, and then double-click to open it.
To distribute orders evenly among the devices, select Distribute Orders Evenly Among Devices.
Select the Order Device Type:
Prep: Select this option if you are
using Prep Displays.
Expo: Select this option if you are
using Expo Displays.
In the Order Device column, select
the KDS Expo Displays or Prep Displays that belong to the distribution
group.
To enter load balancing percentage values for the devices
in the group, deselect Distribute Orders Evenly Among Devices, and then enter the percentage in the Load Balancing
% column adjacent to the device names.
The total load balancing percentage for the order devices
must equal 100%.
