Installing the KDS Client
Follow the KDS instructions to install and configure the KDS client software.
- If you type with a keyboard and nothing appears in the fields, press the F12 key and try again.
- When selecting the Restaurant Display Controller (RDC)
from the list:
- Ensure that the Automatic DHCP Address is turned off.
- Ensure that there are values in the Netmask and Default Gateway fields.
- Ignore the value in the Select Product to Install on Workstation field.
Parent topic: Restaurant Display Controller (RDC) Configuration
