Allowing Employees to Install and Authenticate POS Clients and Service Hosts
You must allow administrator employees to download software, install, and authenticate clients and service hosts using CAL. After granting this privilege, employees can use their credentials to configure POS clients. In addition, the User Security Credentials configured in the Property Parameters module become inactive.
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click an employee role.
- Click the Operations tab, click the Miscellaneous subtab, and then select 10065 - Download Software, Install and Authenticate Clients and Service Hosts Using CAL.
- Click Save.
Parent topic: CAL on Workstations
