Sample JSON: Rappi
The following sample shows JSON code for Rappi. The tables that follow the code sample describe the values in the code.
Tip:
Click Copy to copy the code to your clipboard and then paste it into a text editor such as Notepad++. Change the values for your restaurant and then copy your code into theDeliveryPlatformConfigurationData column
as described in Creating Delivery Configuration in the Revenue Center.
"deliveryPlatformConfigurations": [
"name": "Rappi",
"groupIdentifier": "",
"rvcIdentifier": "1930052575",
"empNum": 2,
"otNum": 1,
"tendNum": 150,
"discountId": 1,
"countryBaseUrl": "https://microservices.dev.rappi.com", //Rappi country base URL. Refer to https://dev-portal.rappi.com/getting-started/#country-domains
"menus": [
"name": {
"en-US": "MenuTitle"
"identifier": "Rappi",
"imageURL": "https://via.placeholder.com/201",
}Table 5-2 Data Extensions Column Name
| Name | Type | Description |
deliveryPlatformConfigurations |
DeliveryPlatformConfiguration[] |
Revenue center’s integration configuration for each applicable delivery platform. |
Table 5-3 Delivery Platform Configuration
name |
string |
Rappi Do not change this value. |
groupIdentifier |
string |
Set to null because the object does not apply to Rappi. |
rvcIdentifier |
string |
Identifier for the revenue center. This is the Site ID obtained during the registration process. |
empNum |
number |
Object number for employee to be used to enter orders received from the delivery platform. |
otNum |
number |
Object number for Order Type to be used for orders received from the delivery platform. |
remakeOtNum |
number |
Set to -1 because the object is not valid for Rappi. Do not change this value. |
tendNum |
number |
Object number for Tender Media to be used to settle orders received from the delivery platform. |
discountId |
number |
Object number for Discount to be used for open discount promotion orders received from the delivery platform. The discountId is required. |
countryBaseUrl |
string |
Set to the domain of the country. See the Rappi API Documentation at https://dev-portal.rappi.com/getting-started/#country-domains for a list of country domains. |
menus |
DeliveryPlatformMenu[] |
Details for menu(s) to be submitted to the delivery platform. Make sure to follow any limitations imposed by the delivery platform on the number of menus. |
Table 5-4 Delivery Platform Menu
name |
TranslatedString |
Display name for menu by locale. |
identifier |
string |
Identifier for menu to be used in tags. Make sure the identifier does not conflict with tags used for other purposes. |
imageURL |
string |
URL for image associated with menu. Upload the menu image to the Oracle Object Store through a dummy menu item. |
Parent topic: Creating Delivery Configuration in the Revenue Center
