Assigning Allergy Information for a Menu Item
When using Rappi, you have the option to include allergen information for a menu item on the delivery service provider application.
- Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
- Search in the master records, and then select the menu item from the list.
- Click the General subtab.
- In the Allergen Class Override field, click Select, select the allergen class, and then click OK.
- Click Save.
Parent topic: Configuring Menu Items
