Adding a Nutrient Set
When using Uber Eats/Postmates, you have the option to add a Nutrient Set for a menu item. Only the Calories nutrient type with either Calories or KiloJoules units are supported.
- Select the Enterprise, property, or revenue center, click Configuration, and then click Menu Item Maintenance.
- Search in the master records, and then select the menu item from the list.
- Click the Nutrition subtab.
- Click Add.
- In the Nutrient Set column, click the ellipsis (…), select the Calorie nutrient from the drop-down list, and then click OK.
- Click Save.
Parent topic: Configuring Menu Items
