Automatic Discounts with Decimal Quantity Menu Items
Simphony ignores decimal quantity menu items with automatic
discounts and applies the discount for the closest whole number. For
example:
1 Cherry Pie = $20.00
1.5 Cherry Pies = $30.00
If you add a menu item to the check with a quantity less than 1, Simphony does not apply the automatic discount.
If you add a menu item to the check with a discount and then split the check, the discount no longer applies to either check.
The following automatic discount rules ignore decimal quantities
when ordering:
Quantity Threshold
Combination Pricing
The discount engine ignores menu items added with a quantity less than 1 (for example .5 cup of yogurt). Understanding Automatic Discount Rules contains more information about Quantity Threshold and Combination Pricing.
Amount Off Examples contains examples of the Amount Off award type.
Amount Substitution contains examples of the Amount Substitution award type.
