Print Class Output
You can use a Print Class to configure the output for Discounts, Service Charges, and Tender Media. This enables multiple records with a single Print Class, meaning you can define the output settings once rather than separately for each record.
A Print Class is automatically created once, only after upgrading from a previous version of Simphony. The Print Class field automatically defaults to the Print Class created for these records on the General tab in the Discounts, Service Charges, and Tender/Media modules. After upgrading, new records must be manually created or chosen in the Enterprise Management Console.
Receipts
Receipts print at the workstation at the end of a fast transaction. They are typically used in a quick service restaurant (QSR) environment where ordering menu items and tendering the check is performed in the same service round.
Guest Checks
Guest checks print at the workstation. They are typically used in a table service restaurant (TSR) environment. Checks usually include a table number or guest name and are service totalled several times before final tender.
Order Devices
Order devices are remote kitchen or bar printers, or KDS devices. These devices deliver the order to the production area from the workstation.
Journal
The journal is not a physical device, but an electronic file journal that provides audit capabilities in the application.
