Select the Enterprise level, click Configuration, and then click Roles.
Select the role type, click the Operations tab, and then click the Miscellaneous subtab.
Select the following Miscellaneous options:
10061 - Allow Access to the IIS CAPS Configurator
Tool
10065 - Download Software, Install and Authenticate
Clients and Service Hosts Using CAL
Click Save.
Before you perform an upgrade to Simphony 18.1 from Simphony
versions 2.9.x or 2.10, you need to ensure that the options described
above are enabled before running the post-upgrade CAPS Configuration
Tool. Specifically, if option 10065 is disabled prior to the upgrade,
after the upgrade, an error message appears during your login to the
CAPS Configuration Tool . If you click OK on
the error message window, you can log onto the CAPS Configuration
Tool, but you cannot utilize the Authenticate CAPS button (added to the CAPS Configuration Tool for the Simphony 18.1
release).
