Configuring the Fire Now Button
To allow workstation operators to fire items on a check from the current service round to order devices, you need to add a Fire Now button to the touchscreen page.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the page on which to place the button, and then on the Edit tab, select the page area in which to define the button (for example, a menu item selection page).
- Click Button, and then on the General subtab, select Function from the Type drop-down list.
- Click the black arrow directly beneath the Type drop-down list, select Fire Now from the Type pane, and then select the Service Total configured as the Fire Now Service Total.
- Click OK, enter a Legend for the button (for example, Fire Now), and then position and size the button on the page. The selected Tender Media’s number appears in the Arguments field for the Fire Now function.
- Click Save.
Parent topic: Guest Checks
