Creating Print Language Buttons
The Print Language function allows the workstation operator to select a specific language. For example, if the secondary language is Arabic, the Print Language 2 button prints the customer receipt in Arabic. Follow these steps to create one or more Print Language buttons.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Add a button to the appropriate screen with the function Print Language 2. Depending on the number of languages, you can create other Print Language buttons (for example, Print Language 3 and Print Language 4).
- Click Save.
