Configuring a Print Full Seat Check Service Total
  1. Select the Enterprise or property, click Configuration, and then click Tender/Media.
  2. Add a new record, and then double-click it to open in form view.
  3. Select 2 - Service Total from the Key Type drop-down list.
  4. Click the Options tab, and then click the Printing Options subtab.
  5. Select 16 - Print Full Seat Check.
    If you also select 14 - Print Seat Check, option 16 overrides option 14.
  6. Select 21 - Print Summary Totals.
  7. Click the Menu Levels tab, and then select the Main and Sub Level on which the Print Full Seat Check Service Total is available.
  8. Click Save.
  9. Add a touchscreen button for the tender/media record that you created in Step 2. Creating a Full Seat Check Button contains more information about configuring the touchscreen button.
Related Topics
