Configuring Suspend and Resume
  1. Select the revenue center, click Setup, and then click RVC Parameters.
  2. Click the Options tab, and then select 60 - Enable Suspend/Resume.
  3. Click Save.
  4. Select the Enterprise, property, or zone, click Configuration, and then click Tender/Media.
  5. Insert a record with the tender name.
  6. Double-click the tender record.
  7. On the General tab, select 2 - Service Total from the Key Type drop-down list.
  8. Click the Options tab, and then click the Ops Behavior subtab.
  9. Select 74 - Suspend Order.
  10. Click Save.
  11. Select the Enterprise, property, revenue center, or zone, click Setup, and then click Tender Parameters.
  12. Click the Configuration tab.
  13. To configure a default Suspend Order tender, in the Default Suspend Order Tender drop-down list, select the suspend order tender.
    A default Suspend Order tender is needed for certain suspend scenarios, such as when a workstation operator is auto-signed out or when another operator signs in.
  14. Click Save.
Related Topics
