Creating Condiment Prefix Menu Items
- Select the Enterprise, click Configuration, and then click Menu Item Maintenance.
- Insert a new record and name it Prefixes.
- Select the Prefixes header record and insert a new record. Enter the prefix (for example, ADD) as the name for the new menu item record.
- Double-click the record you created in Step 3, and then click Menu Levels Tab.
- Select Active on All Levels.
- Click Prices and insert a $0 priced record.
- Click Save.
- Repeat Steps 3 through 7 to create records for the remaining prefixes.
Related Topics
Parent topic: Condiments
