Disabling Condiment Prefixes
You can disable condiment prefixes to prevent them from appearing in the Combo/Condiment Orderer.
- Select the Enterprise level, click Configuration, and then click Menu Item Classes.
- Double-click a regular menu item class with condiments.
- Click the Condiments Group tab, and then change all Allowed Condiment Groups to Required Condiment Groups.
- From the Allowed Condiment Groups section, select the condiment group you created in the section Creating Menu Items Classes for Prefixes.
- Click the Forced Condiments tab, and then set the Minimum value for the previously enabled condiment groups to 0 (zero).
- Repeat Steps 2 through 5 for all regular menu items with condiments.
- Click Save.
Related Topics
