Configuring Access Privileges for Resetting a Password
To access and reset passwords for other users, you need to be assigned the appropriate privileges in the EMC.
  1. Select the Enterprise, click Configuration, and then click Roles.
  2. Click the EMC Modules tab, and then scroll to the Personnel section.
  3. Select the options for the Employees (Enterprise) access privileges for each of the following columns:
    • View
    • Edit
    • Add
    • Delete
    Figure 11-1 Roles for EMC Modules
    This figure shows the Roles module EMC Modules tab.
  4. Click Save.
  5. Click the Actions tab, and then scroll through the Action column until you reach the Security section.
  6. Select the Can Change Others’ Passwords and Email Addresses and Security Questions check box to enable the option, and then click Save.
    Figure 11-2 Roles Actions Security Settings
    This figure shows the Roles module Actions tab Security settings.
  7. Ensure that all users requiring Multi-Factor Authentication (MFA) configuration permissions are assigned a role that have these access privileges enabled.
