PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Distribution Privileges
Select the Enterprise level, click Configuration, and then click Roles.
Double-click the role type, click the Actions tab, and then select the appropriate privileges:
Table 3-1 Distribution Privileges
Privilege Name
Allows the Employee to ...
Distribute
Use the EMC Distribute function.
Remote Distribute Out
Move data from one revenue center to another revenue center
or from one property to another property between two different Simphony
systems. Select this option to allow employees associated with this
role to remote distribute from this Simphony system out to another
Simphony system.
Employees need login credentials
with permissions on the receiving Simphony system to Remote Distribute
In.
Remote Distribute In
role to remote distribute from another Simphony system into this Simphony
system.
Employees need Remote Distribute Out permissions on the other system to distribute in.
