Configuring Task Schedules for Export Reliability
When upgrading Simphony, the Dbupgrade automatically creates two tasks for Export Reliability: one for Workstation (WS) and one for Check and Posting (C&P), but only if these tasks have never existed. The tasks are called ‘Daily WS Export Reliability with recurrence’ and ‘Daily C&P Export Reliability with recurrence’. Default values are used for these tasks.
New organizations created after the upgrade require task schedules to be created manually. Schedules of an existing organization can be used as a template.
Parent topic: Importing and Exporting Data
