Setting the Default Language for Employees
You can configure the default language for employees,
which appears on the following:
POS Operations UI for the logged in workstation operator
Workstation messages and prompts not configurable in the EMC
PMC labels and ad hoc reports
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Employee Maintenance.
- Double-click an employee record to open it, change the default Language of the employee, and then click Save.
- Repeat Step 2 for all employees.
