Modifying the Default Log Archive Purge Settings for Application Services
To modify the default archive purge settings, you need to add entries to four application service configuration files. The following table lists the configuration files for the application services and their locations:
Table 5-2 Application Services Configuration Files
Application Service | Configuration File Name | Location |
EGateway Service |
Web.config |
[Drive Letter]:\MICROS\Simphony2\EGatewayService |
Data Transfer Service (DTS) |
DataTransfeService.exe.config |
[Drive Letter]:\MICROS\Simphony2\DataTransfeService |
Direct Posting Service (DPS) |
DirectPostingService.exe.config |
[Drive Letter]:\MICROS\Simphony2\DirectPostingService |
Sequencer Service |
SequencerService.exe.config |
[Drive Letter]:\MICROS\Simphony2\SequencerService |
Related Topics
Parent topic: Log File Management
