Configuring Active Main or Sub Level Pricing for Current Round
When using the Change Price Level feature, you can also change the active main or sub level pricing for the current round (transaction) only. This allows the active menu (price) main or sub level to be maintained for the current round so that further menu items are priced at the same price level.
  1. Select the revenue center, click Setup, and then click RVC Parameters.
  2. Click the Options tab, and then select the following:
    • 71 - Change Price Main Level sets active Main Level: Select this option to set the active Main Level for the current round after using Change Price Main Level.
    • 72 - Change Price Sub Level sets active Sub Level: Select this option to set the active Sub Level for the current round after using Change Price Sub Level.
  3. Click Save.
