Associating a Menu Item Definition with a Tag
Menu tags need to be added in the Tags module before associating them with a menu item definition. Configuring Menu Tag Groups and Tags contains more information about adding tags.
Simphony Transaction Services Gen 2 uses tags to filter and to group menu item definitions. A menu item definition record can be associated with more than one tag. The menu item master record must have at least one menu item definition to enable the Tags tab in the Menu Item Maintenance module.
Parent topic: Menu Item Definitions
