Setting the Default Menu Levels for a Revenue Center
Select the revenue center, click Setup, and then click RVC Parameters.
On the General tab, select the Default Main Level, and then select the Default
Sub Level.
The values configured in the Default Main Level and the Default Sub Level fields are available
in the Serving Periods module. Configuring
a Serving Period contains more information.
Click the Options tab, and then
set the main and sub menu levels as follows:
To set the workstation to remain at the current main menu level
after completing a transaction, select 23 - Retain Current
Main Level after a Transaction.
To set the workstation to remain at the current sub menu level
after completing a transaction, select 24 - Retain Current
Sub Level after a Transaction.
