Allowing Employees to Begin Waste Checks and Run Waste Reports
- Select the Enterprise level, click Configuration, and then click Roles.
- Select the role type, and then click the Operations tab.
- To allow employees associated with this role to begin waste checks and to authorize other employees to begin waste checks, select 263 - Authorize/Begin Menu Item Waste Check.
- Select the appropriate report privileges as described in
the following table:
Table 30-2 Menu Item Waste Report Privileges
Privilege Name Allows the Employee to ... 31062 - Run Employee Waste Report
Run the Employee Waste Report from the workstation.
31063 - Run Menu Item Waste Report
Run the Menu Item Waste Report from the workstation.
31064 - Run Waste Summary Report
Run the Waste Summary Report from the workstation.
31065 - Run Waste Detail Report
Run the Waste Detail Report from the workstation.
- Click Save.
Parent topic: Menu Item Waste
