Configuring the Autosequence Event Schedule
  1. Select the Enterprise level, click Configuration, and then click PC Autosequence Schedules.
  2. Insert a record for the autosequence schedule (for example, Nightly Batch). If the autosequence schedule record exists, skip this step.
  3. Double-click the record to open it.
  4. On the General tab, enter information in the following fields:
    Table 12-9 General Settings Fields
    Field Description
    Autosequence
    Select the autosequence event from the drop-down list.
    Server Name
    Enter the name of the server located at the Enterprise level or Hosting Center.
    Time Zone
    Select the time zone of the Enterprise level or Hosting Center.
    Schedule Type
    Select the frequency for the autosequence event.
    Duration
    Select Enabled for the autosequence event to run.
    Select the Start and End dates for the autosequence event.
  5. Click the Recurrence tab.
  6. From the Daily section, enter the number of days for the autosequence event to reoccur. For example, to run the event daily, set this value to Every 1 day(s).
  7. From the Daily Frequency section, set the time or times for the autosequence event to run.
  8. Click Save.
