Configuring the OPI and SPI to Settle Transactions Automatically
You can configure the OPI or SPI settlement to run automatically at a recurring day and time. The settlement occurs at the Coordinated Universal Time (UTC) standard. Here are a few configuration examples:
Workstation Time Zone: Eastern
Recurrence Time: 15:00
Configuration 1 (There is no conversion to UTC in this case)
Time Zone: 0 - Local Time Zone
Time Settlement Occurs: 15:00
Any event with a Time Zone is converted to UTC. This is best illustrated with Configuration 2.
Configuration 2
Time Zone: 35 - Eastern Time Zone (UTC - 5) (Daylight Savings Time is active)
UTC Time Settlement Will Occur: 19:00
Configuration 3
Time Zone: 260 - Brisbane (UTC + 10)
UTC Time Settlement Will Occur: 05:00 Tomorrow
- Select the Enterprise or property, click Configuration, and then click Task Schedules.
- Insert a new record for the OPI or SPI EOD, and then double-click the record to open it.
- On the General tab, in the Service Type drop-down list, select 8 - Check and Posting, and then select 5 - EOD Settlement as the Task Type.
- In the Schedule Type drop-down list, select 4 - Recurring - Daily, and then select Enabled in the Duration section.
- Select the Start date, and then click No end date.
- Click the Recurrence tab.
- To set the SOD settlement:
- In the Daily Frequency section, select Occurs once at.
- Schedule the EOD settlement to execute at the same time SOD runs on the property.
- To set the EOD settlement:
- In the Daily section, enter 1 in the Every xx day(s) field.
- In the Daily Frequency section, select Occurs every and schedule the EOD batch settlement time to execute.
- Click Save.
