Post-Uploading Cloned Data Instructions
Once you have successfully uploaded cloned data, you need to access the EMC for the new environment and perform the following:
Employee Configuration
Most personal information data contained in employee records is not cloned during the data extraction process. Your new environment now contains only partial employee records which can be used to log on to the EMC (for example, as the default user). Users need to configure employee information such as their first and last name, password, email address, and enable their access to generate Reporting and Analytics reports, and so on.
See the Oracle MICROS Simphony Configuration Guide, specifically the Employees and Privileges chapter and the Configuring Employee Privileges for Oracle Hospitality Reporting and Analytics topic in the Reporting chapter for more information.
Reporting and Analytics Integration
Reporting and Analytics configuration data is not cloned. Users need to map all associated properties and revenue centers to the Reporting and Analytics environment.
See the Oracle MICROS Simphony Installation Guide, specifically the Post-Installation Tasks chapter, and the Connecting Reporting and Analytics to Simphony topic for more information.
Workstation Configuration
Existing workstations are erased during the cloning process. Workstations for the targeted location need to be updated with their correct host names, subnet masks, and default gateways.
See the Oracle MICROS Simphony Configuration Guide, specifically the POS Workstations chapter for more information.
CAL Package Configuration
CAL packages are not cloned. As with standard operations, you need to assign CAL packages to the workstations. After this is complete, workstations with updated CAL packages can begin to process transactions.
See the Oracle MICROS Simphony Client Deployment Guide for more information.
Parent topic: Cloning Simphony Database Configurations
