Setting Offline Transaction Posting Time
When a property or its workstations are unable to communicate with the database for an extended period of time, transactions do not post. You can determine whether offline transactions post using the current time or the transaction time once communication resumes.
  1. Select the property, click Setup, and then click Property Parameters.
  2. Click the Options tab.
  3. To allow offline checks to post to the database (when communication with the Check and Posting server is re-established) with the actual time of the transaction, select 6 - Post Offline Transactions with Actual Transaction Time. Deselect this option to allow offline checks to post with the time that the check is uploaded into the database.
  4. Click Save.
Related Topics
