Configuring Custom Images for Table Management
You can load custom images into the Simphony application to represent table seating configuration and statuses. The TMS uses both custom images and images packaged with Simphony. All images are transparent Portable Network Graphics (PNG) files.
Table images show a graphical representation of the table and chairs. These images can be a square or round table surrounded by any number of chairs.
Table decorators show a graphical representation of the table status (for example, dirty, closed, or reserved).
- Select the Enterprise, property, or revenue center, click Setup, and then click Content.
- Double-click the content name row to view the image set for that name.
- Click the Import from a file link to import custom images.
- Browse to the file location, select the image file, and then click Open.
- Repeat Steps 2 through 4 to import each table image and table decorator.
- Click Save.
